1998 Yamaha 150 HP 2 stroke<br /><br />When shifting to forward it gives you that grind like you did not shift crisp. Once in forward it stays and runs fine. Shen shifting to reverse it is harder to get into gear and tends to pop out at times. <br />I am thinking the clutch dog is shot and replacing the lower unit will fix the problem. I am pretty sure the clutch dog is difficult to get to and requires special tools? <br />Mostly I want to make sure this can't be some sort of shift cable problem? I dont want to put a new lower on and have the same problems.<br /><br />Thanks
