Re: Yamaha Overheating???
From my experiences, they don't really go bad, they are just a plastic plug. What happens is that they stick in their seat or there is not enough water pressure to force it open all of the way or they get clogged up. I read on another forum a guy with a similar problem. He pulled the poppet valve out and ran the motor. He could not duplicate the overheat. He was told that over time, the spring can get harder to push together. Just get a new spring.<br /><br />If the poppet doesn't solve your problem, then I would suggest verifying 100% that you are overheating. My engine has been "overheating" however, when I pulled the cover and felt the cylinder heads, they were cool enough for me to hold my hands on for a few seconds. So then I pulled the leads to both thermo-switches and ran her. The rev-limiter kicked in again. So I unplugged the thermo-sensor, ran her and as expected, no rev-limiter since all heat sensors/switches were disconnected. Plugged the thermo-sensor back in and I could not duplicate the problem. Plugged the switches back in and still no overheat alarm. Who knows? Weather and a wedding kept me in this weekend.<br /><br />One last thought, just be sure your rev-limiter is not kicking in due to low oil. You don't want to be chasing the wrong problem.<br /><br />Good luck.
