Shermanator31660
- May 15, 2006
- 88
Another guy I know who has the same motor came up with a question I couldn't answer, imagine that ! When the motor tilts down, there is a "pinch point" where the motor bracket engages the clamp area, the motor binds when it hits this and slows the descent. Same thing when you tilt the motor up, it is very slow going up at first because of this binding, but once it clears the clamp it goes up quite fast. Question is, is it supposed to do this and if so why. Its quite a drain on the battery in cold weather because of the time it takes to lift the motor from from the down position..... Sherm
