Yam Exciter 270 Both Engines Start, won't stay on when key released from 'Start' posn
Regarding the "Yamaha Exciter 270 Neither Engine Turns" posting (Summer 2009), I suspect you've probably figured out the problem by now--likely either the safety cut-out switch in the back cleanout hatch, the lanyard safety switch, or another one at the FWD/N/REV control (must be in Neutral to start). I too have a 270 Exciter (1998), and have had my share of troubleshooting experiences (including an engine rebuild) over the past 2 years that I've owned it.
Since I'm new to this forum, I haven't figured out how to post my own new thread, so I'm replying to that post and changing the title. My latest dilemma happened a couple weeks ago and doesn't make any sense to me. We were on the water idling when both engines shut down (separate timing). I was able to restart both engines, but could not release the key from the start position without the engine conking out (immediately like I had turned the key to 'off')--both engines reacted the same. Additionally, I could not move into fwd or reverse without the same effect. After drifting out of the channel towards some nasty bushes and shallows, I finally found that I could rev up an engine in idle and actually move forward slowly, which bought me some more time to try to resolve the problem. I knew my battery would not take running the starter too many times, and luckily after about 50 attempts at slowly backing off the switch I was able to release it and we were on our way. I wasn't about to back off the throttle and risk having to start all over, but with only 1 engine I can't get on a plane and we were several miles from home. So I found a nearby dock and called my wife to come get 'the crew' while I would 'limp' the boat back home. After everyone else was safe, I again had to go through the same lengthy process of attempting to release the key, this time to almost the point that the battery was depleted, ultimately being successful, and I made it home just after nightfall.
This failure continued to be a problem the next day when I flushed the engines, even after letting the boat dry out on my boat lift. It seems to be a double failure, because the only real culprit I can imagine is the key switch--everything except the battery and the main safety cut-off lanyard is completely redundant, including those safety cut-out switches in the cleanout hatch, but since I was able to get the engines started every time I know neither of those common components are the problem. It seems VERY unlikely that I would have a double failure at roughly the same exact time. Does anyone out there have any thoughts? Many thanks!
