I've read several posts about the 'oil level' rise in these outboards and was wondering if anyone has been able to correct the problem... if it is a problem.
My motor has 38 hours on it and the engine was serviced at 20 (break in) with oil change, etc.. I've been watching the oil level and it has risen above the 'full' mark on the dipstick, it smells of gasoline, looks diluted and is darker that I think it should be with only 17 hours since oil change. I talked with an outboard mechanic at boat dealer about the problem before I started keeping a close eye on the problem and he spoke about all of the issues: blow-by, condensation and fuel pump diaphragm leaks. He did say that if the oil on the dipstick smelled of gas then there is a problem and that I should have it looked at.
Is anyone going through this issue with their outboard? If so, what was the outcome?
Thanks..
Thanks..
