jim dozier
- Jan 8, 2003
- 1,970
Re: WOW! new 4 stroke 50 merc
The difference in emissions with direct injection engines such as the Etec is that the fuel isn't injected into the combustion chamber until after the ports close. As a result there is a lot less unburned fuel going out the exhaust port. Remember that in a normally aspirated 2 stroke the only thing keeping the fresh fuel charge from going directly out the exhaust port (and as a result contributing to high emissions) is the direction of the charge in loop charged ports and the piston deflector in cross scavenged ports. Neither of these are 100% effective. With direct injection, if applied efficiently, you may lose some air out the exhaust port but the fuel isn't added until the ports are closed and you get a cleaner burn. Also I would expect that you can regulate the mixture a litte tighter because you don't have to account for fuel dropping out of the mixture during contact with the crankcase and ports in the initial mixture. Remember there are lots of variable in what determines emissions. <br />Fuel/air mixture. <br />Degree of mixing.<br />Charge stratification.<br />Combustion chamber shape.<br />Port timing and efficiency.<br />Combustion temperature.<br />Ignition timing.<br />I'm sure there are other issues.
