I went to do the WOT timing as per the top secret file by TD. Problem is I can't turn my motor over with the throttle at full because of the neutral safety switch in the control box. Is there an easy disable or do I disconnect the throttle cable from the motor and just put the lever forward to the timing stop?
Thanks.
Thanks.
