Took out the 1988 211 liberator yesterday ran great then started to miss a lil on a 10 mile cruise up river then on the way back it would plane up then shortly after would back fire and die. Lil hard start but would, It would only run at a fast idle for 10 miles. I'm thinking timing but not sure. Any suggestions. Thanks newbie here to a bigger boat.
Hey, I have one of those! (mine is a 1987 211 Liberator!!)
Things to check will be fuel related. On mine, I removed the fuel tank completely cleaned it out. luckily, mine was free of water and debris. I did replace the vent hose and through deck fitting and I put a new gage sender in it..
Fuel pickup screen. you have to remove the rear seat (completely) and remove the cover over the rear of the tank. There's a fine mesh screen at the end of the fuel pickup inside the tank. while you have that out, you can replace the anti-siphon check valve.
Fuel vent. If the vent is plugged with debris or bugs etc, the fuel pump will not be able to draw fuel out of the tank for very long until the pump suction equals the fuel tank vacuum. if you remove the fuel filler cap right when the engine dies, and you hear a loud sucking sound..... It's air rushing back into the tank!!
Then inspect/replace the flexible hose that goes from the anti-siphon valve to the fuel filter. (Those hoses if old enough will slough off debris inside and it'll end up clogging your fuel filter)
Check/replace your fuel pump. If it's old, change it. If I still had the one I removed from mine, I would send it to you. But I don't know what I did with it...(I don't have the 460 anymore) probably wouldn't be a bad idea to replace it anyway.(the pump that is!)
You should have stainless steel lines from the filter to the pump and to the carb, but I would ensure that they are clear of any debris.
Now, before you do any of this, disconnect the fuel line at the carb, remove the spark plugs so the engine will turn freely, remove power from the "+" connection of the coil so it doesn't "spark", and crank the engine to see if you have good fuel flow from the fuel pump.
Another thing you can do is get a small portable fuel tank and hook it to the suction side of the filter and draw fuel from it.
If you don't know the history of the carburetor, it might not be a bad idea to rebuild it. But unless you have a lot of "stuff' in the tank, filter is full of "stuff" the carb might be ok. I took mine apart after 20 years or so and the only thing wrong with it was the gaskets I destroyed taking it apart. Your carb should be a Holley 4160 series carb. They are very easy to rebuild and you can get a kit at NAPA.
I wouldn't immediately assume it's the carb though. start with troubleshooting the fuel delivery to it first!
Regards,
Rick
