Re: Will it fit ? for Joe R or Dhadley
I'm not an expert on CDI systems, especially for boats... BUT the recommended rating on that system sounds like a CYA by the manufacturer. If it's not a jobber system (which it certainly doesn't sound like) then if the voltage reaching the unit does ever break the 16v barrier it shouldn't immediately effect it. After pro-longed high voltage, especially high voltage spikes, then you're asking for trouble. Most components used in CDI systems for motorcycles (the ones I've seen) are usually rated well above what the manufacturer specifies as the max, but extra voltage does equal heat and eventually the magic smoke will be released.<br /><br />It almost sounds like to me you should check the rectifier unit, if you haven't already done so. Just checking the charge going to the battery isn't going to cut it. Disconnect the rectifier and check each of the diodes (if it doesn't say how to in your manual I'll be glad to help you out). Also check the resistance of your stator windings. Everything may seem fine when it's running but you could have have an intermitant short happening. You may also have a bad ground connection on your rectifier unit itself. This is probably the most important ground in the charging system, check it and clean it. <br /><br />If there isn't a voltage regulator already on the motor I'd have to say that the rectifier also houses the regulator (very common practice). Again if you experience a voltage spike this would point to a bad ground as this is where extra voltage is bled off by the regulator system. <br /><br />If all else fails and you want to keep a close eye on the voltage going to the CDI unit, install a cheapo volt meter so you can keep an eye on it.
