Canufixit2
- May 20, 2016
- 99
60hp 2019 Merc 4S OB engine/ Props w/ hub II kit. Will changing from Hub kit II to Hub kit III fix the prop rattle? Though I read this somewhere ? Thanks
I have the same issue on an Evinrude for which they don't have an OEM solution. Been advised to switch on the Flo-Torq II for a Rubex Hub60hp 2019 Merc 4S OB engine/ Props w/ hub II kit. Will changing from Hub kit II to Hub kit III fix the prop rattle? Though I read this somewhere ? Thanks
I have this issue with a ct 115. Is it just at idle
