Re: Why am I getting tongue bonce?
Posted from
uhaul's website
Tongue weight
The downward force exerted on the hitch ball by the trailer coupler. In most cases, it is about 10 to 15 percent of the GTW. To tow safely, the tongue weight must be sufficiently positive when the trailer is empty and/or when fully loaded. Check the height of the tow vehicle's bumper before and after loading. If the loaded trailer doesn't drop the height of the bumper by at least another inch, then reposition your load with more weight in the front of the trailer. Check out how to determine GTW & TW capacities.
copied from
hitchingup.com
tongue weight
Tongue weight is the downward force exerted on the hitch ball by the trailer coupler with weight-distributing devices, if any, deactivated.
Tongue weight should be approximately 10% to 15% of the total weight of the trailer.Generally, more is better, but much more than 15% may actually increase the likelihood of sway, especially if the tongue weight approaches or exceeds the tongue weight rating of the tow vehicle. Note that this applies to pop-ups, travel trailers, and utility trailers. Fifth wheels often run at 25-30% tongue weight (because the tow vehicle can take it), and tractor-trailers average near 50% tongue weight.
copied from
etrailer.com
Trailer Loading
The way you load the trailer can determine how easy you can tow it. While loading, keep in mind that the tongue weight should be 10% to 15% of the overall trailer weight. One of the main causes of trailer sway is not having a large enough percentage of trailer tongue weight compared to gross trailer weight. To help prevent the trailer from swaying back and forth, a few things can be done. Try placing heavier cargo in the front of the trailer, ahead of the trailer's axle. Also center the cargo left-to-right and use tie-downs to keep the load from sliding.
Trailer Sway can also lead to a loss of vehicle control. When starting out with a new load on a trailer, make sure it will not sway by gradually increasing your speed in intervals until highway speed is reached. If the trailer does begin to sway, try adjusting the cargo and equipment accordingly and then repeat the test. If repositioning the load and equipment did not help reduce the sway, a sway control or a weight distribution system with sway control may be needed.
Also look at this chart on
curt's website... shows 10% tongue weight or
this calculator on changingears.com
Here is an excellent writeup on sherline .com
Now can we get back to helping the O/P or as I said before START YOUR OWN THREAD if you must continue.... this is not fair to the O/P?
