- Sep 26, 2009
- 19,798
2003 60 Johnson 4 stroke
Rated max WOT rpm 5300
Current max WOT rpm 5300 - perfect!
Top end around 32/33 GPS
Current prop - OEM 14x17 #177131 AL
Here it is, not my ad and it sold anyway.....
Johnson Evinrude 3 Blade Aluminum Prop 14" x 17 Pitch RH 177131 | eBay
Looking at a SS. Here's my options:
17” Pitch Johnson Outboard Boat Propellers 60 HP 1998 & Newer 4-Stroke
The only performance issue I'd like to be a little better would be the holeshot..........
Here's the 2 I was looking at from iboats.
This one is supposedly made for 4 strokes and mentions an excellent holeshot:
Stiletto Advantage Q + Guardian Hub Stainless Steel Boat Propeller #801317 for Johnson 60 HP Outboard 1998 & Newer 4-Stroke
This one is vented which should also give an excellent holeshot:
Turning Point Express Stainless Stainless Steel Boat Propeller #3143 1711 for Johnson 60 HP Outboard 1998 & Newer 4-Stroke
Which would you go with, or, is there another one that would outperform the aforementioned?
It's been said to drop a pitch going to SS. They have both in 15" as well the others.
Would I really need to drop pitch, especially the one that is vented? Thoughts being the venting would offset the smaller pitch. Keep in mind this is a 4 stroke..........
Thanks fellas...........
