Kid of confusing. You stated that; "I did unhook the outdrive and I can move it freely However, the steering is frozen." What moved freely, the outdrive or the steering wheel? If the outdrive moved freely then you have either a steering wheel issue or the more likely, a steering cable stuck. I would lean towards a stuck steering cable. Probably time for a new one. If you can remove it, that would tell you which one was the culprit for certain, and you could see what type and length you need for a replacement. It usually is stamped on the steering cable. JMHO
