Re: where to find this rims?
I think you are measuring incorrectly. If you are measuring from the center of one bolt hole across the wheel to another hole you are not measuring the bolt circle. The only way to measure that accurately on a FIVE bolt wheel is to measure from the center of one bolt hole to the center of the large hub hole and then double that. From one bolt hole to the center of the hub hole is 2.25 inches making the bolt circle 4.5 inches. If you had a FOUR bolt wheel, then you can measure to opposite holes.
