You're welcome. The bolt on a factory engine shouldn't be painted and should have a rubber stop on it. Not a big deal though, yours may have been rebuilt and resprayed.
If you're bogging coming out of the hole, I'd check the throttle cam is properly aligned to start the carb butterflies opening when the roller hits the cam at the line. Not the START line, the unmarked one. If that's right, you may have carb problems.
Your idle timing doesn't matter. What does matter is your idle speed. In gear, tied to the dock, about 700 rpm.
