Re: Whats the point of changing oil for winter hybernation?
Acids do indeed form in oil, but motor oil has buffers in it that neutralize the acids as they form so the acids are not a problem until the buffers are used up. Fortunately, there's a lot more buffer capacity than is necessary for typical change intervals. That same "acidic" oil you are worried about leaving in all Winter, was in there all Summer too...
I have steel parts from a motorcycle transmission that sat in well-used (6000 mile) motor oil for 5 years, sitting on a shelf in my garage. They have no corrosion, whatsoever. Nor do the crankshaft, pistons, or rod bearings from the same engine.
I change mine once in the Fall, immediately after my last trip out as part of my Winterizing routine. It's easy to pump when the engine is hot. I only do 70 hours a season so it's an yearly event for me.
