Re: Whats the difference between a car and a boat starter?
Well, Kudos to Bondo and Haut for keeping me and others straight!! (& I mean it btw!)
I hate it when I mis-speak with out having all the "stuff" to back it up.
I (incorrectly, I might add) lumped many things together where they probably shouldn't be lumped!
While it's true that one MUST have ignition protected "things" in a boat they're not always required if they can be protected from ignitable fuel "vapors" as indicated below.
It appears that people that operate boats with "automotive parts" that do not have enclosed engine compartments (Or ANY engine compartment ) where the engine is hanging out in the breeze, seem to comply with the 183.410. They also do not have to have a blower or water cooled exhaust system either. The water cops on most lakes don't seem to be that interested in checking to see if the starter or alt has an SAE J1171 tag on them.
That would probably come after the insurance company comes calling to see what they could find in the burned out wreckage to get them out of paying the claim!!
I'll add that I would
NEVER use a NON-marine starter, alt or other engine part or even suggest that someone else do the same!
Cheers,
Rick
The following is excerpted from
http://www.gpoaccess.gov/ This gets you to the page I copied it from
183.410 Ignition protection.
top (a) Each electrical component must not ignite a propane gas and air mixture that is 4.25 to 5.25 percent propane gas by volume surrounding the electrical component when it is operated at each of its manufacturer rated voltages and current loadings, unless it is isolated from gasoline fuel sources, such as engines, and valves, connections, or other fittings in vent lines, fill lines, distribution lines or on fuel tanks, in accordance with paragraph (b) of this section.
(b) An electrical component is isolated from a gasoline fuel source if:
(1) A bulkhead that meets the requirements of paragraph (c) of this section is between the electrical component and the gasoline fuel source;
(2) The electrical component is:
(i) Lower than the gasoline fuel source and a means is provided to prevent fuel and fuel vapors that may leak from the gasoline fuel source from becoming exposed to the electrical component; or
(ii) Higher than the gasoline fuel source and a deck or other enclosure is between it and the gasoline fuel source; or
(3) The space between the electrical component and the gasoline fuel source is at least two feet and the space is
open to the atmosphere. (emphasis mine!)
(c) Each bulkhead required by paragraph (b)(1) of this section must:
(1) Separate the electrical component from the gasoline fuel source and extend both vertically and horizontally the distance of the open space between the fuel source and the ignition source;
(2) Resist a water level that is 12 inches high or one-third of the maximum height of the bulkhead, whichever is less, without seepage of more than one-quarter fluid ounce of fresh water per hour; and
(3) Have no opening located higher than 12 inches or one-third the maximum height of the bulkhead, whichever is less, unless the opening is used for the passage of conductors, piping, ventilation ducts, mechanical equipment, and similar items, or doors, hatches, and access panels, and the maximum annular space around each item or door, hatch or access panel must not be more than one-quarter inch.
