Whats the best way to clean my inboard props?
Doc's Holiday
I have a 330 Sundancer on the hard for the next couple of weeks.I noticed ther is some build up on the props and rudders. Is there anything I can apply to remove the buildup or is elbow grease the best way. This is a freshwater boat,andI have tried briefly sanding with a 18volt drill motor and a cheap sanding disk.
Re: Whats the best way to clean my inboard props?
CLR? or toilet bowl cleaner should work. my guess is that you have calcium buildup.
Doc's Holiday
Thanks I'll give it a try.
