Re: Whats the best brand power pack to buy, OME CDI or Mallory
If it's not the power pack witch I will know Monday night when it comes. What should I look at then. I am stumped when it comes to this wiring of the motor thing.
Listen to everyone who has said perform the proper tests. It could be the kill switch which you are pretty sure it's not but not really sure it's not(it could be the circuit, not the part of the switch you can touch), it could be the stator, it could be the timer base, or in a really unlikely scenario you could have 4 bad coils.
SparkieBoat's sig line has the standard tools and troubleshooting procedures. Let's just say for the moment that it is the powerpack - maybe it's the powerpack because of a part earlier in the ignition system which will kill this powerpack.
Don't let the testing scare you. If you just but the $25 tool and follow the instructions (check the blue wire for this number, check the orange wire for that number, etc.), it is really easy.
I'll throw another recommendation in for CDI. And don't buy used ignition components
Used cost + New cost > New cost, and you spend more time boating and less time wondering if you're still having the problem because the used part was no good.
