BrianSmithFishn
- Jul 18, 2016
- 26
I bought an old 80's bass boat off a buddy for $1200 it has a old mercury 115hp on it. Serial # is B182713. I can not find anywhere what year it is, I even went to two marina's and they couldn't figure it out. I need to find a service manual on it first and foremost. I want to compression test it first so I know what I'm dealing with. However I don't know what is the minimum psi suggested by the manufacture considering I don't even know what year engine it is. This is my first boat I am trying to get it on the water. Planning to replace the water pump, spark plugs, fuel filter, test the thermostat, clean carburetors, already cleaned out the gas tank, change gear oil, and I'm also curious about the prop shaft oil seals and bearing carrier how ever it does not look like others I have seen, so again need a service manual. If you guys could help me out it would be greatly appreciated, thank you so much in advance!
