I see lots of threads on trailers being too short/not properly supporting the transom, but can it be a problem if a trailer is too long?
Would love to know what the experts here think. I'm looking at putting a 20' boat on a 22' tandem trailer. The centerline (hook to plug) measurement on the boat is 17'6. The trailer measures 18'2" from bow stop to bunk ends.
I have two things on my mind that might cause problems, but I'd be glad to hear any others:
1) the tongue weight will be increased due to there not being enough weight rearward of the trailer wheels.
2) the tie down straps will not secure the rear of the boat properly because they will be free floating rather than snug on the transom
I guess you could fix #1 by moving the axles forward, or moving the bow stop back.... I'm a little nervous about anything that would involve welding through. This particular trailer does not have much behind the rear wheel to begin with (pic below).
IF #2 is a problem, then I'm thinking a stern strap would be an easy solution.
Thanks in advance for the input!
