Re: What thrust washer?
Walleyehed, The reason I re-hubbed the prop is going from v-4 to v-6 it was splined different. When I use the OMC thrust washer I get to much to much exhaust ventilation due to the prop not seating into the gear case and the Yamaha is about the same. There is about a 1/4 inch gap between the prop and gear case. The result is 6300 rpm @ WOT. I think going from a 19 aluminum to a 17 stainless should be ok and turn about the same rpm and I turn about 5400 with aluminum. Thanks for any help.
