UncleWillie
- Oct 18, 2011
- 3,995
Are you sure it is wired correctly?
There are two power paths to the ignition coil.
One path supplies reduced power to the coil through a ballast resistor whenever the key is ON.
The other supplies full 12v power through the starter only while cranking.
If it starts and then dies just as you release the key, the the ballast supply has a problem.
