I have a J6RLEU that won't start, even after 15 pulls, unless I squirt a syringe full of fuel directly into the carb. The motor has 100 psi in both cylinders; I have done the procedures in the "hard start" FAQ's. I have rebuilt the carb; checked the spark; synch & link; set the low speed valve per Mr. Reeves; checked the fuel supply by disconnecting the hose at the carb and squeezing the bulb; and checked that the choke closed properly.
Once started, the motor runs beautifully; and restarts with 1 pull for about ? hour; and then it won't start without the syringe. What can I do next?
