Re: What needs to be done with too much oil in mixutre?
He should get a mixing 50:1 fuel/oil ratio bottle to make exact mixtures, his engine will work as it's best, meanwhile soak spark tips in acrylic thinner for some minutes and brush away excesive oil with a tooth brush, clean plugs treads. Drain gasoline from bowl, test, if the engine does not idle well clean carb interior, replace with new 50:1 mixture.
Happy Boating
