I've got a 17.5' bass boat that I had to replace the transom on.
I've got the new wood epoxied in and the back/bottom epoxied back on as well but I need to fill about a 1/4" gap between the existing boat and the piece on the back/bottom that I cut off and have now epoxied back on.
For the bulk of the job I'm using a 1:1 epoxy resin.
I found some epoxy putty at Home Depot but don't know if I dare use that on a boat.
The exterior surface will be covered with 1.5 oz. chopped strand mat and epoxy resin.
What can/should I use (cheap!!) that will fill that gap and a few unrelated small holes (1/2" x 1").
