evinrude bayliner
- Apr 2, 2007
- 41
I have a mid 70s model Evinerude starlite 85hp evinrude outboar. I have been getting some leakage of fuel at the bottom of the of the carburator face plate in the lower right hand corner. This is the main plate where you would take the cover off to inspect the carbs or clean them with cleaner. There is a hole that comes from the carbs through the wall of the plate. When the engine is running you can see tha gas mixture streaming out of the hole and is leaking down the bottom of the outboard into the water. Is this normal? Please help.
