snake91876
- Jun 25, 2007
- 211
How do i set the floats on these plastic carbs where the float stays in the bowls when you remove them. This is a 1991 200hp johnson. I have set the parrellel to the body of the bowl but they seem to be flooding and dumping some gas out . All throats were extremely wet with gas and she flooded so bad she wouldnt run and get on plane. I was using ql78yc plugs when i should have had ql77jc4 i dont know if this had anything to do with it. Thanks
