There are several plastic part on the outdrive unit. The manual specifies no lubricant. Is this right? I understand that those parts move very little, but still. Isn’t any lube is better than no lube at all?
Those pars include: bushings on the pin rod of the power trim; synthane washers on the bell housing; wear pads on the drive shaft assembly.
Thanks.
Thanks.
