Firemedic09
- Jul 1, 2008
- 46
i went out to look at and possibly work on and order parts for my motor which is a 1986 force 125. right where the lower unit mounts to the other half of the motor there is oil coming out and running down the unit to the ground. the motor is completely tilted up i dont know if this makes a difference. my question is this is well above where my fill hole is for the oil. is this residual from running it the other day? is this a common problem? what do i need to do to fix this? if you are familiar with my other post you know the story behind this. the good thing is the oil didnt have a milky appearance! haha
if i end up having to pull this apart to fix it i need a little help with the seal kit. the link below is the one im talking about. its #74 on the ref. part it says seal kit. is this everything i would need for seal? if there is more can you please point them out? what else would be wide to replace while im into it?
http://www.mercruiserparts.com/Show...6/30.png&inbr=1227&bnbr=10&bdesc=GEAR+HOUSING
