Re: Were Ya'll at???
Changed plugs, full power now. Have changed Racor filter, added some PRI-G (recommended by Honda distributor says mechanic at marina), water separator and fuel pump filter bowls checked good but none of these helped. Plug change appears to have done the trick. 100 hours on plugs but they are 3 years old and per manual should have been changed now. I still think old fuel a primary cause. Just don't run it enough. Hurricanes here slowed boating in some areas due to clogged canals from storm debris.
