Re: Well Pump Mystery
Roboat...several factors may be affecting your problem. You don't mention all of the particulars for your well set up, but rule out a few few things first. No doubt you've let the water run for a while with the pump operating to rule out lack of water?? If so begin to check all the compenents that could cause the problem.<br /><br />Pressure switch - if you have access to it, pop the cover while the well pump is running and manually click it off, in the way that reaching shut-off pressure would automatically, does the pump shut off? Often the quarter inch pipe supplying water to the switch fills with corrosion and does not allow the switch to operate properly, system should over-prssurize though. Same goes for pressure gauge <br /><br />Pressure guage - make sure you're getting an accurate reading.<br /><br />Sounds like your system has a foot valve - if you pressure tested you've probably ruled this out. When your pump reaches 26 lbs, if you manually shut the pump off, does the system stay pressurized at 26, or is there loss when water is shut off...if pressure loss, the water is going somewhere - back into well, out through leaking pipe or valve, etc.<br /><br />Pressure tank - if bladder type, make sure it's pressurized correctly, it should be labeled and pressurized according to manufacturers spec.<br /><br />Finally, the pump - usually, if they're running they'll reach the spec that it was made for, but the impeller could be corroded and not allow the efficient operation you expect.<br /><br />Not doubt there is a lot to check, and it does not sound like you have access to looking in the well itself or even some of the hardware at the well head. You may need that...check all the above ground (inside stuff first).<br /><br />P.S. - don't listen to the crap about 60 foot well being subject to more contamination than 200 foot wells, after all, isn't some portion of a 200 foot deep well 60 feet below surface? It all has to do with the well construction..ie; dug, drilled, pounded, etc. and how the ground water is sealed off with casing. If ther's no casing then you're probably getting ground water, but still...percolation through 4 to 5 feet of soil is usually sufficient to cleanse septic effluent. That's why septic systems need only be 100 feet away from wells, that much distance is way safe enough.<br /><br />Good luck diaqgnosing your problem...keep us 'posted'
