- Mar 8, 2009
- 40,796
Did the freezer thing and removed the old wear ring. Took the new 155mm ring from the freezer and slide it in part way and it started dragging a bit. Pulled back out and measured with a micrometer and was the same thickness as the old one in non-wear areas. Put it back on and pushed it down into the housing, was pretty stiff getting in, but its all the way in.
The wear in the old wear ring is not perfectly even all around, little more in a couple areas. The issue is now, I cannot turn the impeller, pretty stuck. I'm thinking the starter will have an issue if it is installed. Anyone else have this issue?
