thunderroad
- Jun 19, 2005
- 417
69 Merc 160. I did a complete tuneup in May. Points, condenser, plugs, cap, rotor, wires, fuel filter, set dwell and timing, compression even, all around 130-135. The boat has run like a champ all summer. This Saturday it seemed a little doggy. Sunday was worse yet, to the point of actually running rough out of the hole. So tonight I did some investigating. No. 1 cyl had very little effect. Plug looked wet so I put in one of the old ones I took out in May. Engine was instantly back to running smooth and felt strong. But during the testing I couldn't help but notice how weak the spark looked when I did the old screwdriver-in-the-plug-wire thing and when I hooked on the new plug and watched it fire. Even when it would nail me as I took off plug wires, I didn't even flinch. So my question...would a weak coil cause this, or do coils get "weak"? Maybe they just either work or don't. I've had the boat three years and the coil is the one that was on it when I got it. Connections on the coil are clean and tight. What about those "high performance" coils? Any value in them or is this just the nature of the beast? I'm not comparing it to spark like an electronic ignition. I'm still around a lot of engines with breaker points and this one just seems like it has a weak spark. Or should I just leave well enough alone and be thankful that at the moment I'm worrying about a weak spark instead of something major?
thanks
thanks
