snake91876
- Jun 25, 2007
- 211
I had no spark, tested stator, timing base, power pack. Timing base had odd ohm readings and only dva voltage on two wires. I decided it was bad so replaced that and powerpack. Checked spark and would not jump spark tester but gets weak spark on plug gap but not very bright. Replaced plugs and starts and runs suprisingly well. Takes the throttle and revs good. Why is my spark so weak i have the copper wires and a plug Ngk Br8hs which i dont think is prefered. Would this have anything to do with spark , im scared under load this things going to break down.
