fishthebay
- Aug 17, 2001
- 180
First, I want to thank everyone that walked me through getting my lower unit off.<br /><br />I went to the boat store today and purchased the waterpump kit/ with new housing and also a thermostat.<br /><br />I asked the mechanic at the marina about how to install the new waterpump correctly and he told me the following-<br /><br />Grease the impeller and also the inside housing. Slide the impeller down the shaft and then the housing. Rotate the driveshaft clockwise and that will allow the teeth on the impeller to bend in the right direction and get it into the housing.<br /><br />Then he told me to put the lower unit back up and rotate the flywheerl clockwise to align the shaft.<br /><br />IS THIS ALL CORRECT??? What are you thoughts on greasing the inside of the housing and also the impeller.<br /><br />Also, my driveshaft has a few pits of rust on it and he told me to lightly sand the shaft and apply grease.<br /><br />Thanks in advance for your assistance.
