Hi I've got a 2001 2.5l powerhead that I bolted to an older mid shaft lower unit.. Problem I'm having is I'm not getting enough water pressure when taking off.. I have to keep the rpm right around the 3000 mark until it builds pressure or the buzzer goes off and motor goes into limp mode.....once it build 5psi then I can go full throttle and works fine and climbs right up to 17psi at WOT.. What would cause low pressure like this... At idle I have 0 pressure but water is coming out both hoses... if I goose the throttle in neutral the pressure gauge dose move.. I'm lost on what to do here.. I've replace water pump dropped motor thinking it wasn't low enough in water... Any help would be appreciated thanks
