the machinist
- May 7, 2002
- 711
Re: Water pickup tube Evinrude 15HP
The 2nd tube you see on some (exhaust water tube) will/will not be there depending on the year of Mfg. Early ones from 1974 to maybe 1980 (now don't hold me to this date) would have not had any exhaust tubes but just blubber away from under the upper outlet, later they had tubes maybe 4" long & then later yet maybe 10".
My thoughts here are that the 74-76 had no tell tale, but used a blubber hole that exhaust water was mixed with exhaust gases, so they needed no tube as the blubber hole was high on the outer housing. After the tell tale was used, this just idea lingered there for no real reason, but maybe they finally figured the water did better getting it away from the powerhead ??
