I have a 96 stingray 658zp with a 350 mag and alpha gen2. This weekend I pulled the out drive during winterization to find a pool of water in the u-joint bellow. I replaced the gimbal bearing, bellows and shift cable just last season. The boat doesn't take on any water and everything seemed fine prior to pulling the drive. I did however notice a very slight loss of gear lube from the reservoir over the season, probably a 1/2 inch over the whole summer. I haven't drained the drive yet so I'm not sure about the condition of the gear lube. My questions are:
1) The gimbal bearing is the sealed type and feels smooth, should be concerned and/or replace due to the water?
2) The bellows appear fine. What others sources could there be for the water intrusion? Is it possible that the gaskets where I pulled the drive could be at fault?
3) What do I need to look at that could have been damaged as a result?
Any input is appreciated.
Thanks
Thanks
