Last time we had the boat out, I noticed that the gear oil looked milky. I to it to the dealer, they did a pressure check and vacuum test on it and can't find a leak anywhere. They think that a seal became loose and when they changed out the lube that the seal reseated and everything is fine.<br /><br />What do you guys think? I am picking up the boat after work and we are planning on taking it on its last cruise of the season in a couple of weeks. I just want to make sure I don't have anything to worry about.<br /><br />Oops forgot to add that the engine is a 1999 3.0L Mercruiser I/O on a 17' Starcraft 1710.<br /><br />Thanks.
