sweetmarie
- Sep 27, 2005
- 115
Re: Water in bottom cylinders v6 Evinrude 175 hp
Wow. And all six should be visible? All on the outside of the cylinders like the one shown?
I'm guessing they run all along the inside of the powerblock and feed water to the top? Good working order meaning not blocked. Can I remove them to inspect?
While I have your attention, in the pic shown, the arrows are pointing to the temperature indicator wire. Can it be disconnect at this point? I would then be able to bring the head to the work bench for clean upl
Thanks in advance
You should have 6 water passage deflectors [#322411] which are pieces of rubber hose. It is absolutely necessary that they be correctly placed and in good working order.
Thanks in advance
