Re: Warning horn sounding with switch turn on
The oiler is a vital part of the motor, obviously, keeping oil mixing with your gas. If there is any doubt about it, you can leave it disconnected, mix oil with your gas and the VRO will just become a fuel pump. Thats the cheaper alternative to the problem. Otherwise run 50:1 in your tank and monitor your oil usage. Mark your oil tank with your boat level on the trailer, and make sure thats its using before you go back to straight gas.
Bruce
