Re: Want to add a 10 micron
You mean before the primer bulb, (Should go: Tank (antisyphon valve), Water seperator, primer bulb (which technically should be outside the outboard in the well deck area) engine. If you are running 2 tanks, water seperator should go after selector "Y". Make sure you make good air tight connections, I recommend OMC gasket sealing compound on barbed threads barbed connectors, no teflon. To make sure you do it right use proper sized "Oeticker" clamps. A water seperator is going to add some slight fuel restiction, so you might want to check fuel restiction afterwards. When testing the boat side of the fuel system I have used an electric fuel pump from NAPA or Autozone approximately 6-8 psi, and hooked up a vacuum gauge inline and attached it to the low pressure fuel pump connector and routed the exit end of the fuel hose back to the tank, this will simulate a WOT low pressure fuel pump draw without taking the boat underway.
