I've read quite a lot about id'ing the outdrive by finding various numbers and such, but none of mine seem to line up correctly. In other words I need help. This is what I know;
I have a 1984 fishcraft houseoboat with a AQ200D volvo penta 305 cu in engine. Where the mounting asembly for the outdrive comes through the transom there is a plate with the following numbers, PN 850678-8337 and SN 647996. Also on the top of the outdrive u joint housing their is a plate which reads, PZNR 28148778B, and "Made in Sweden", however there is not a ratio or any other number. I have a crack in the intermediate housing which I am preparing to change out and want to be sure that I identify the outdrive correctly. Some literatures says it is a 280B and some says 290. Any help would be appreciated in a big way.
thanks,
Rick67
thanks,
Rick67
