There is a plate above the prop on my volvo dp sm drive that was cracked and missing a piece. It appears to be part of the Planing surface of the drive as well as part of the exhaust.
Anyways, looks like I have to split the upper and lower sections to get one bolt out of that plate. Question 1. Can I drop the lower of the drive and reinstall it easy enough willout pulling the whole drive from the bellhousing?
Question 2, any seals I need to buy before I attempt this? I assume there is a water pickup tube in there, and some seal or oring for the outdrive lube?
