4winnsskipper
- May 9, 2007
- 204
Well after an outing with the boat just today, i noticed a noise...a bad sounding noise...engine/drive have 44 hours on them, 96 volvo penta 3.0 with sx drive. boat has been used very little obviously, and stored on trailer. Engine runs great but when i went to turn the boat with engine in forward gear, the more i turned the boat, the louder the noise got, like a bearing noise....turn drive straight, noise completely gone...
at the begining of the end of last year during winterization i removed the drive, greased the u joints and gimbal bearing with grease spec'd by my volvo manual, ujoints appeared to the be in good shape, looked brand new and i could not make play in them, seemed solid enough. i also greased everything till new grease came out, and whip the old off. i also used an engine alignment tool, and the tool slide in 100% of the way in, no problem, very very little resistance, basically drive was ligned up. i also put new bellows on, both u joint and exhaust....im at a loss what this could be.... im thinking gimbal bearing......i dont know why it would go at 44 hours, maintained regularly...perhaps the u joint bellow is leaking?!?! i also have NEW fluid in the drive, ultra HPF gearcase lube, also per my owners manual. filled to the top, from the bottom, and checked via dipstick with drive level..............
thanks guys for any help in advance!!
