Chilly5001
- May 13, 2015
- 13
Hi all, I have a 1996 75 hp force by merc that I recently replaced the starter and starter solenoid on. After cleaning all the connections and charging my battery it cranked (easier than it has in a while). I took the boat out and quickly noticed the radio wouldn't come on. No big deal, probably a loose wire or something I figured I'd investigate later.....I then noticed the nav/anchor lights would only come on intermittently and they seemed to go off immediately if I tried the radio again. The horn would only occasionally work as well.
The pontoon stays outside all year in the water and hasnt been driven since late august so I wasnt too worried if the radio didn't work. On my way back to the dock I noticed the volt meter creeping up to 18 and slowly returning to about 14 where it normally is when underway at a reasonable rpm.
Any ideas? My battery is 4yrs old. I charged it 3 weeks ago to 100% and when I went to recharge it yesterday it was @ 44%. All my connections (that I altered) are clean and tight. I'm a novice and don't mind call a mechanic buy y'all have been very helpful in the past and have allowed my to learn a lot and save significant $. Thanks!
