grewvin1
- Apr 2, 2012
- 189
Have new radio Solaris and new antenna. Soldered on the connector all as instructed signal transmit weak compared to my buddies with this the same rig.
How long do you have to have the cable? thinking there is too much and have resistance as i did not cut any of the cable off. The antenna is less than one meter from the radio on the side of the boat as most are installed. Then i have all the footage that came with the antenna piled in the side of the hull with the rest of the boat wiring bundles to the dash. Need to know if would have better signal if i remove all but about 1-1/2 meters of cable to cut down on interference and resistance.
