themacdadt
- Jun 20, 2010
- 16
2006 75 hp Optimax . I pulled both thedrain screws on the vapor separator to remove any water/contaminets, the o rings where not on the screws. Screwed both back in when I was done and the filter side sealed with no leaks, but the float chamber side will not seal I keep getting a trickle out of the drain. So my question is ....are the orings supposed to be on the screw or are they known to come off the screw and stay in the housing of the separator? What can I do to get this screw to seal?
