Looking for a few opinions...
I have looked at a used Johnson outboard. It is a 1984 25 horse. Seems in decent shape. It had been used by the current owner for 3 small outings, then stored in the garage for 3 years. I went to look at it a week ago, but it would not start, a mouse may have severed the stop button wire connection. The owner repaired it and called me back. We ran the motor in a tank, and it seemed to start and idle nice. We took it out of the tank for further inspection.
I noticed a lot of rust color on the painted surface of the lower unit. It was not seen originating from seams or drain points etc. I opened the lower unit to check the lube, and a cup of water drained out, then grey fluid. That was my biggest sticking point.
Then I noticed that this is not a short shaft, but measured a good 20" maybe even 22" from the transom clamp to appx center of prop. Although, it was mounted on a short transom boat.
I guess my questions are these:
1. Should I be very concerned about the water in the lower unit?
2. How hard/expensive is it to reseal the lower unit?
3. How much will a long shaft motor affect performance/safety on a small transom boat?
I run in treacherous/rocky areas, so I am a little concerned over potential damage with a longer shaft motor - but maybe its still worth it.
Thanks,
Jeff
Thanks,
Jeff
